duranged03
- February 5, 2012
- Oklahoma
- 2003 Explorer XLT
Have spent several hours reading and researching, I have a project in mind, that I may be flamed, banned, and hunted down for. May not get much help, but worth a shot. My 03 2wd, 4.sl0w sohc, I know what the main end result Im looking to do is, but unsure of several things still and some final pieces are undetermined.
I'm looking for external dimensions of the stock engines in the expy, V6 and V8, as the 4.0 will be replaced with a V8, but NOT the 4.6. I know a few have done the 4.6 swap and have had many obstacles and some havent finished the swap. I'm planning an even more challenging swap, I have patience and determination. Im pretty good with wiring, and have done several swaps and crossbreeds, but not where I needed to make totally different computer platforms interact and communicate properly.
Does anybody have dimensions of the trans tunnel and the factory trans external measurements? What about the rear diff and cv axles, what can be done or changed to make them reliably handle up to 450 ft/lbs torque? Just a good high number, dont know exactly what its going to push yet, but I have a goal.
Weight of the stock engines and trans? Fully dressed.
What all does the bcm control, and what all has to communicate with the ecu? I plan to install an aftermarket alarm/remote start system so not too concerned with all the extras like lighted keyless entry, etc. But if I can keep the bcm, and retain functions without the original ford ecu and mimic signals its looking for from another ecu than thats a plus. The gauges, Im thinking about going all aftermarket, The dummy gauges are definately not even a consideration for the build with the way Ford set them up to pretty much guess at settings and take readings in intervals instead of instant.
What It really comes down to, is, Id like to retain much of the vehicles factory function and appearence outside of the engine bay.
What about airbags and abs systems? Do they run off the bcm/ecm in any way or standalone systems? I also need it to be able to pass a state inspection for emissions, so other than being a newer engine and retaining emissions equipment, what else needs to be considered?
Anything else Im not listing that you can think of, feel free to post, its late and im tired and hadnt really planned on posting tonight. Other than posts telling me im dreaming too much or not to try it or it cant be done etc. I will make it happen one way or another, but thought maybe somebody here could help with some of the research anyway on sizes and weights, and wiring info. also if you can point me to some pinout diagrams or anything that would help.
I would also like to retain AC if possible, and if somebody wants to trade me for a V8 explorer I may just consider doing that right now lol. I know most people get the response, trade it in on a v8, I dont want to just trade it, I wanna build something totally off the wall and unsuspecting. I want somebody to pull up and think, hey, just another v8 explorer with exhaust..... Main point is, its mine, its paid for, its got problems, its got miles, i like the design (body, interior, and suspension designs), i like how its setup, i wanna build a toy.
