expo5.0
- October 18, 2001
- Red Wing, MN
- 1996 xlt
dash started smoking today and everything shut down on the truck. took dash apart and investigated to find a black and white 16 gauge or so wire melted. ripped into it further and found that wire was 1 of 8 wires that appear to be the same and connect to two larger gauge bl/wh wires in the middle of the dash. (all of thse wire were located in the main wire pack running through the top of the dash- they appear to go on to the ecu)
also, found that my factory ground strap on the back of the motor was melted/cut. these problems definitely seem to be related.
anybody have a good diagram of where that grounding strap actually mounts to my 5.0? i can't see it from the top and until i fix this my truck is stuck all the way down (exhaust on the ground).
my hypothesis is that the ground wire got messed up and shorted out the other wire leading ot massive failure. i need a guiding hand in how to proceed from here and get the truck running again. can't leave it where it is for now.
