thefranchise713
- April 22, 2016
- Buffalo, NY
- '18 Toyota Prius Prime
Huh. I must have missed this message some months ago. Just in case this poster is still lurking...
Voltage and State of Charge are being measured differently by the BCM. Just because you maintain a system voltage of 13.5+ while the vehicle is running does not mean that the state of charge is at a sufficient level to keep the BCM happy to prevent load shed.
An example of this is when the vehicle is jumped. The alternator will bring system state of charge to 13+ volts, but the state of charge will be far lower until the system actually fully recovers. When the car powers down and the MFT powerdown message comes on, it's more than likely triggering off the State of Charge number being too low in the BCM as opposed to a voltage read.
The triggers of a load shed are different for when the car is engine on vs. engine off. When the vehicle is engine on, it's more concerned about maintaining system voltage as trigger for a load shed. When it is engine off, it's more concerned about the State of Charge reading. Voltage is reveiwed and SOC is reviewed in both conditions if I recall correctly, but one is more important than the other depending on the engine run state.
Ok
So are you saying that charging V's during use are high enough to be acceptable and to start the car?
I'm good with that.
But if that is true, why would the low battery message that comes on at shutoff is indicating the state of charge is too low? Or the batt V is too low? It's been charged sufficiently, no?
The contradiction of the above two statements is where I am hung up.
Why would a battery being charged at 13.5V throw a low battery V message? Is it the nature of HOW and WHAT information is being analyzed from the real time performance data to determine whether to throw the message at shutdown?
