Vinniety
- January 31, 2007
- Westchester county, NY
- 2000 sport
Well here we go again...in some of my previous posts i complained about codes..p0171 and p0174 and marble sounds. Well it seems that the errors went away with a new mass air flow sensor and the marble sounds came back again after changing the oil. I used mobile synthetic 5-20 like i have in the past. I just ran seafoam and it helps alot but the sounds always come back. My new issue now is that i get a miss feeling when i drive for the first 20-30 minutes. If i shut it off on the side of the road for about 15 minutes and wait the problem will go away but what the hell can this be? I have ownerd the truck for about 7 months and i never had this issue before. Last time the truck did it i left it running and i tapped on everything i could under the hood. What i mean is the IAC, the mass, the plug wires anything that i think can be causing it. I also thought it might be the fuel pump but i dont know. I have encoutnered this issue with a quarter of a tank and a full tank of gas. The tune up was done by previous owner. He has autolite plugs and i am not sure of the type of wires. Maybe a plug is bad? I also noticed that i unplugged the throttle poistion sensor and it did nothing was the truck suppose to do somthing maybe stall? Need help on this.
thanks
thanks
