kid0ry
- October 1, 2011
- Long Beach, CA
- 1999 Explorer SOHC 4.0L
I know there are a few different threads out there that relate to my issues, but i wanted to start this new thread to get some specificity.
1999 Explorer V6 4.0L OHV
I was getting a misfire code p0306. I replaced plugs and wires and checked compression. Reset ECU and the code still came up. I then bought a new coil pack form clark's (garbage cheap prices and products). I installed it and it ran worse! It felt like the engine was gonna snap off of the motor mounts... So I put the stock coil back in and (being a starving college student) bought and replaced only the 6th cylinder fuel injector. Upon registering all the sensors the check engine light came on again. This time it read p0304. I hadn't had time to poke around down there for some time. But when I finally did I read code again, p0304 came up like last time. But p0306 came up again too! Oh, I'm also slowly losing coolant...
There are many things that come to mind. Im pretty sure i don't have a vacuum leak, but I'm going to pull all my plugs and check em and run another compression test. I'm also going to run an ohm test on the coil. I also read a little about COP boots? I'm not a mechanic in the least. This is my first time working this in depth with an engine, aside from basic tune up stuff. What and where is a COP boot?
Anyways if all this checks out and I'm still getting misfires I will move lower and replace ALL the fuel injectors this time.
Until then I would like to say thank you in advance for taking time to read this and for any suggestions and guidance.
My next post will explain all results (with pictures if need be)
