Missing / Bucking at 40-45mph | Ford Explorer Forums
jmason
Sicklerville NJ
2000 Mountaineer V8 - AWD
2000 AWD V-8. 107,000....When it gets to 40-45mph, if I give it gas, seemingly putting a load on, prior to it downshifting, it bucks and hesitates. Especially when hot...I did replace the plugs and wires a year ago with taylors. Plugs are Motorcraft Platinums. Now it doesnt do it when i floor it, or at idle, or highway speeds...Only between 40-45, once in a blue moon 45-50mph. I do not see arcing at night, but it doesnt do it at idle..I have a set of OEM wires on order; I am going to take the Taylors off. When it does this behavior, no codes are sent, and the misfire monitor always says OK with the reader...
Any ideas besides the wires? I would think if it was the trans, or mechanical, it would have other bad habits...please advise. :us:
vapor lock?
Flooding?
Cat converter?
No codes you say...wow
Start with the arcing wires for one.
Before the trans downshifts from OD to 3 it bucks badly? Falls flat on its face?
Does it recover?
My first impression would be a bad thottle position sensor. You can probably duplicate that problem in third or O/D at that rpm (the rpm you are running at 40-45) because of the higher gearing. Might be tougher to duplicate it in 1st or 2nd cause of the lower gearing.
TPS is kind of like the accelerator pump on a carburetor... when you jump the gas its the amount of signal change from the TPS that tells the computer how much extra gas it will need.
No codes from a cheesy TPS. But give the MAF a good cleaning first.
Fixed !
I replaced the taylors with a set of bosch OEM wires....While doing this, i noticed the no. 8 boot on the spark plug side had a pinhole burn mark...it was literally a pinhole. i cut it open, the boot was burned through from the inside out. the exit hole was tiny.....why i never got a code is beyond me. thanx for the replies !
Pretty wierd that a spark plug wire problem would only show up at a particular speed!
re:
Yea it was wierd. I suspect if I let it go much longer, it would have eventually been all the time. What I am most suprised about it that It wasnt giving me any misfire codes.
