n.a.mccanna
- August 28, 2011
- Auburndale, Wisconsin
- 1994 Mazda B4000 4WD
I have a 94 Mazda B4000. It is the 4.0L, automatic with roughly 278000 miles on it. The only modifications are the alternator, when from the stock 95 amp to a newer models 130 amp. Two 10" JL Audio W0's and a 600 watt JL amp. Other than that the truck is stock. About a week ago the engine started missing. I checked the plugs and didn't see any that are burnt black...they all seem to be the same in that there is kinda this rust color on them. These plugs are roughlt 9 months old along with the wires.
The missing seems to be happening mostly right above idle and at cruising...under full power the truck typically runs fine. But I can't just keep my foot in it all the time (I don't mind but the cops sure would!).
I'm going to swap out the plugs today and run some injector cleaner when I fill up today but any other suggestions would be greatly appreciated!
I'll post after the new plugs are in and I've run it a little bit.
