Spdrcer34
- March 14, 2002
- Bremerton, WA
- 1992 Explorer XL
The Radius Arm Crossmember in my Explorer is in the way of me dropping in my 5.0L/4R70W.
I want to know if anyone has modified how I am going to do.
I want to make it a 3 piece set-up, instead of a 2 piece.
I will cut the cross member about 2 inches inbound from each Radius Arm hole. I will remove the clips and bolts from the now removed center section. I will slide the pieces apart a couple inches so it will bridge the 2 remaining brackets still on the frame. Weld the 2 pieces together to make it a solid center section. Then re-use the clips and bolts to secure the now solid section back into remaining brackets on the frame.
The MAIN reason I would like to do this, is for ease of transmission servicing, and/or pulling the Engine and Transmission as 1 assembly if I ever need to. Un bolting 4 bolts to gain the clearance is a LOT better than loosening the RA bolts, AND the other 8 bolts or so to drop the whole bracket.
What do you think of this idea? Has anyone done it? Does anyone NOT understand what I am thinking of doing? Any drawback to this design?
Ryan
Ryan
