Mono or Dual channel for 2 subs? | Ford Explorer Forums - Serious Explorations
Silverblade
BC, Canada
97 SOHC
Do i want a mono or dual channel amp if i am wiring it to 2 subs in the same box?
Mono is better for subs, they are class D and use less power then a 2 channel amp would.
Or you could also use a dual channel and bridge it.
it will be cheapest and most efficient to use a mono amplifier
if you don't already own an amp buy a mono
and make sure to bridge the subs in the box so your running 1 wire from the amp to the box, not two. (wire em in parrallel)
unless you buy a mono amp that has two terminals pre wired in parellel- such as a mtx
sort of a nice feature eh?
