ndaniels1987
- October 25, 2012
- West Virginia
- 2002 Ford Explorer
I recently purchased a 2002 Explorer 4.0. I went out the start the vehicle on morning and the motor only turn maybe half a turn then I heard a loud clunk. So my first thought was the starter. I removed to the starter took to a local parts store and had it checked. It is a good starter. I have power down to the stater so I knew that wasnt the problem. So I decided to turn the motor by hand. I removed the plugs and put a breaker bar on the crank nut. Nothing Happened. I removed the lower oil pan and found some plastic looking parts and a couple peices of metal. After doing some research I found out the parts look very similar to the timing chain tensioner.
So my question is, Is it possible to replace the timing chain with out removing the engine from the vehicle? I have already removed the radiator and am now having trouble removing the Fan and Fan clutch any info will be appreciated.
