This could be in the wrong forum, so please advise........
I have a 2002 Merc Mountaineer. I've been adding Lucas fuel treatment to each new gas fill. The styrofoam seal at the top of the fuel treatment bottle "could" have gotten into the fuel fill line. I'm not for sure about this, since the seal is now missing, and I can't find it, but I've lately noticed that I have an extremely slow gas fill issue. The fuel nozzle will kick off if much of a flow rate is present. I disconnected the gas fill downtube, cleaned it completely, and have disconnected the hose going to the tank. Since these orifices are quilte large in diameter, I don't suspect them to be the issue. I noticed that when the full fill hose is disconnected from the gas tank, there's a backflow preventer plunger that when depressed will let gas flow out of the tank. Could the styrofoam seal have gotten somehow behind this plunger and doesn't let gas properly flow into the tank?
Thanks,
Rod
Thanks,
Rod
