MTX and Bazooka | Ford Explorer Forums
MTX and Bazooka
Mikes98
Allen, Texas
'98 Sport
does anyone know if the mtx 502 and the bazooka rs series(800watt) have the same or can use the same amp wires? and if so is there somewhere where i can get the setup graph for both?
Ok,
When you are saying amp wires, which wires are you speaking of? If you are talking power wires, the answer is yes. If you are talking RCA cables, again the answer is yes. If you are talking about the high level inputs(coming straight from the headunit, without RCA cables)), the same wires can be used, but they have differnt hookup connectors. Theres usually a standard color scheme to high level inputs. Grey/grey stripe, green/green stripe, white/white stripe and brown/brown stripe.
i dont like mikes98 explorer and his subs dont hit hard at all i know bcuz i have heard them in his car...he needs to get back together with lil flip cause they were a cute couple.... :)
you need to have at least 8 gauge for the 502 amp your looking to install
hope that helps
and wtf was that other part about...
christian, your a ***, you better watch it, your just jelous that i have 3 12's and you have 2 10's :) but you do have a limited
you guys probably want to watch the language a little, family oriented type thing going on here. many peoples kids read the site.
not that i have any though- heh i'm 21.
i just thought i'd warn you before a moderator gets mad
