Thank you! Sorry about that.View attachment 175038 I turned the photo around for you so it's easier to read
Thanks - I appreciate the welcome!I just discovered these forums yesterday. I had a Forester before, and had been on those forums. I moved into a larger vehicle as my family has been growing (and the ST was really appealing).Welcome to the Forum Adam.
Could be a chronic issue during assembly if the machine attaching the sub-frame is causing the issue. Would like to think mine and others can be rectified with something so simple. Still an assembly quality issue non the the same. Roll on.....
I have, but the manual is somewhat vague. It says that it enables the last climate control settings, and the dealer says that the heated/ventilated seats and heated steering wheel are not considered climate control settings (that climate is the vents and air temperature).Have you checked your Manual to see if that is normal?
I noticed your in Portland I recommend taking it into Landmark ford, my friend works there as a mechanic and he says they are top notch!I have, but the manual is somewhat vague. It says that it enables the last climate control settings, and the dealer says that the heated/ventilated seats and heated steering wheel are not considered climate control settings (that climate is the vents and air temperature).
Thanks! I appreciate that. I have heard great things about Landmark. I went to Damerow (which is where I bought my ST) and I was pretty happy with the service department. If I have issues, I will definitely consider Landmark.I noticed your in Portland I recommend taking it into Landmark ford, my friend works there as a mechanic and he says they are top notch!
The other issue I thought I had, I say thought because the dealer told me it is working appropriately, is that when I would use remote start and I had last settings enabled (as opposed to Auto, which will heat or cool to 72), the Explorer would turn on my heated seats and heated steering wheel (or ventilated seats) even though those were not my last settings. The dealer told me that, even on last setting, the Explorer will still turn on heated or ventilated seats, even though I never use those. I find that odd, but who knows!
I have the same thing going on, only when remote start (with last settings set) does it turn on only the drivers seat cooling. I have just learned to live with it but will ask the service dept next time i am in for service.
Multiple suspension noises is the only problem I have. This video of them test driving the ST in the city at low speeds on almost even surfaces is making the same clunking noise at 4:25, 11:45, and in more. High way or higher speeds I don't hear the clunking noise, but this is the noise that is making this clunking sound.
Just got my ST back after 7 weeks in the shop. Dealer replaced front struts and towers in effort to remedy the clunking noise. Did not work, clunk is still there. I will be dropping it back off in the a.m. and start over. Still awaiting claim from ford regarding buyback.
The dealer said it was hard to pinpoint the noise. They also said a couple other STs on the lot did the same thing. I will advise them about the bolt when I drop it off. ThxDo they have another ST on the lot? If so, did you take it out for a ride to see if it still does it?
Why is the dealer giving it back to you if it is still doing it? I'd think they would have test drove it to confirm if it is gone or not. Did you tell them about the bolt of the subframe that another member posted about that wasn't installed correctly and once they replaced it, it fixed the sound?
I am thinking that this rattle is limited to 4WD variants, as it all seems to be platinum AWD and ST AWD. No complaints from 2WD peeps?
Must be me but I've watched both times now 7 times each and can't hear anything beyond the bump in the road at the 4:25 mark.
