VinceL
- May 24, 2011
- Frisco, TX
- 2013 Explorer Limited
so should i be worried if my unit is "in production" right now and i cannot pull up the window sticker yet?
You should be beyond worried, you should be terror stricken!!!!!
Nahhh, just kiddin'
I would think if it is in production, you should be able to pull up the window sticker.
Try this LINK, it seems to work most reliably and check to see if it will bring up your window sticker. It is the site that I use. I guess you could also double check to make sure you are entering the VIN# correctly??
