My Explorer wont start | Ford Explorer Forums
kenny57
2002 Ford Explorer
Hi I have a 2002 Ford Explorer and it died on me Saturday at a stoplight. And when I tried to start it I had nothing . No click , it wouldn't even turn over. But I had all my panel lights and head lights. I was told to check the fusible link but I cant find it. I am not a mechanic but I am trying to play one now and I need help desperately.
Welcome aboard!! :salute:
I recently had a no start situation similar to yours. All lights & electrics worked but I had nothing when I turned the key. Here's a list of what I did and what ended up being the problem:
2002 XLT - V6
Was leaving my buddy's house this evening, of course he has left for the night and won't be back here until the morning, and when I turned the key I got absolutely nothing. No crank, no clicking, no nothing.
Have had no warning signs that this was about to happen. After attempting to start it I noticed that the odometer/tripometer/compass readout only displays dashes "--------" and no numbers. I put a meter on the battery and it read 12.6 volts. I am by myself and, therefore, cannot get a reading while attempting to start the Ex.
I tried jumping it and still got nothing. I am checking my shop manuals now.
Any help will be greatly appreciated. I really don't want to spend the night in my truck!
Thanks for looking in.
Yes Fuse #39 showed 0 volts with the key in the run position.
More importantly, I am back up and running. Here's a list of what I did and what the problem ended up being. You are going to love this!
  • Checked battery voltage: 12.6 Volts
  • Attempted jump start: No Luck
  • Checked all fuses in Battery Junction Box: All Fuses Good
  • Checked all fuses in Central Junction Box: All Fuses Good
  • Checked voltages at fuses 37-41 as directed by waskly: 12.6, 12.6, 0, 12.6, 12.6
  • Checked ground strap on engine block: Good
  • Checked starter ground: Good
  • Checked ignition relay: Good
  • Checked starter relay: Good
  • Checked PCM relay: Good
  • Checked voltage at terminal B on starter: Good
  • Checked voltage at terminal S on starter: Good
Here's what ended up fixing the problem:
Was going to remove the starter so I could bench test it. Prior to doing this I disconnected the battery cables and noticed that the terminals where pretty corroded/dirty. So I cleaned the terminals & connectors and the Ex fired up like a champ!!
I can't beleive that I overlooked step 1 when dealing with electrical issues: check battery connections & cables. Hey, I never said I was the smartest one here. My buddy, who knows nothing about fixing vehicles, was laughing his a$$ off. He kept repeating "Auto mechanics 101, check the battery connections."
Thanks for your help waskly. I really appreciate it! :D:thumbsup:
Start by checking the battery & alternator.
I have the shop manuals and can forward info upon request.
Hope this helps out. :biggthump
Be sure to check out the 3rd Gen Sub Forums:
Modified 2002 - 2005 Explorers
Stock 2002 - 2005 Explorers
Happy Exploring. :biggthump
Welcome to the site. You could use a test light on an ohm meter and test the link to see if it's bad.
