jake122288
- May 17, 2009
- Pleasantville, iowa
- 1994 4-door xlt 4x4
I'm on a journey now. but first here is a bit of background.My trans went out on my 1994 X. typical for the a4ld. I then bought a truck for parts with a good trans in it (a 1991 X)did the swap and also did a lift and now put 33's on it. i got everything done and buttoned up and worked great drove maybe 50 miles total and my eec fuse blew. I traced that back to the 3-4 shift solenoid grounding out and when i pulled the pan most of the insulation of the wire was missing. (still needs fixed waiting for vb gaskets and such b4 i start the teardown) this is not my main issue now tho. before i discovered this issue, Today i pulled the truck into the garage (drove it just fine like i have been the last few weeks (its all the driving it seen since the trans install minus the initial test for a 4 mile round trip down my gravel road) Not twenty minutes later i had to drive it a mile down the road to jump start the battery on my work truck and about half way to that truck i lost all forward gears. revers still works like a champ tho.As sooon as i put it in any forward gear it acts like its in neutral. i dont even feel an engagement of the forward gears like normal. there wasnt a slip, a grind, a noise or anything. I was about half a quart low on trans fluid but i instantly topped it off (i carry spare fluids of every sort and kind) didnt fix the issue. i got the truck home but now im looking for possible culprits and im not comfortable tearing past the pump I feel it can be ruled out due to having reverse but i could be wrong) in the trans or the valve body... so im looking for possibilities in these areas. (starting in the valve body)
I recall reading somewhere that low pressure due to a bad vb gasket can cause this or also possible metal shavings/gasket material sticking a valve open/closed in the vb. any and all input advice is greatly appreciated. its nice to know im not on this journey alone and have the great support from the guys here!
