my tires are wearing strange | Ford Explorer Forums
sheepman
Spring city Utah
97 XLT
I have never been able to figure out two things.
1 why are the tires on my explorer wearing on the inside frount more than normal? alingment? it seems to steer fine i have alinged all the chevs I owned over the years how tough could this be?
2. how can I post a question on this forum off the new member site?:confused:
Welcome to this forum! Each section has an icon on the upper laft hand side to post a new thread. I suspect that the alignment might be slightly off, so it's not noticeable, but could cause an uneven wear pattern. Alignment consists of:
1. Toe in & out.
2. Caster.
3. Camber.
If the tires are over inflated or under inflated, it might affect the wear pattern too.
ok so can I check this at my own shop witha tape measure or do I need a shop to do this?
I had a problem with the inside of the front drivers tire that had worn very badly. I pulled the tire off, and my outer tir-rod end was just about ready to brake off. I replased the tie-rod end and rotated the tires and now the front has almost no wear on them after about 10k miles.
Thanx guys now i know where to start...jack it up and check for tie rod wear and ball joint wear. Further comment Friday on my progress.:salute:
