- January 14, 2001
- Fresno CA
- 86 ranger no more
- Callsign
- KK6TDL
I was out driving it today for the first warm day this year. It is hovering around 100 degrees. Truck was running slightly warmer then usual on the temp gauge if I pushed it hard 70mph 3k rpm in 5th. If I backed down to around 65mph the temps would come back down. As I was driving on the freeway I noticed the check engine light came on for maybe thirty seconds then went off. Did it twice maybe 10 minutes apart from each time. After it went off I continued about ten miles and got off the freeway and pulled into the shopping center I was going to. As I pulled into my parking spot it started to sputter and not idle. I shut it off then tried to restart it and it wouldn't start at all. I went into the store to do my shopping (15 minutes), Came back and the truck would start run about 10 seconds then not idle and die. Went and grabbed lunch (45 minutes) came back truck started with somewhat of a rough idle and I was able to drive it home two miles and park it.
I ran my scan tool and I got 3 codes.
157. Mass airflow low voltage
186. Fault in injector pulse with circuit high.
528. Clutch switch circuit fault.
This is in a 93 ranger with a 4.0 and a 5 speed. Need to get this solved as I have a wheeling trip planned this weekend. Going to try cleaning the MAF sensor right now but am lost on code 186. Any ideas?
