Mysterious check engine | Ford Explorer Forums
X-North
Montreal
I just did around my town 5 to 10 kilometers and suddenly a Check engine lighted. After one kilometer i made a stop at my bank and stopped the truck. 5 minutes after that i restarted the truck and the check engine light was gone. Is it a CM code that was there but solved or is it a running code that went out because i restarted the truck ?
It will store a CM code to indicate what fault the computer saw. The CEL goes off if the fault goes away. KOER codes are only set during the KOER test.
Ok but is it stored again if the light never came back? I made a ride today and the light never reappered. For the KOER codes they are set during koer test but like it tell Running engine ...so it is supposed to be a check engine light too when the truck is running down the road ...no???
When the computer detects a fault, the light comes on and a code is stored in CM. If the fault goes away, the CEL goes off, but the code remains in CM. If the fault doesn't recur within ~80 drive cycles, the computer will clear the code from CM. If you've only driven a few times since the CEL came on, the code should still be in CM.
