bigben22
- March 12, 2007
- New Castle, VA
- 1995 explorer sport
Hi all,
Wow! new member here. What a wealth of information. I have a 1995 ford explorer sport 4x4. 4.0 sohc. I assume it is a 4r44e. The auto shifter has drive and 1 and 2. overdrive also of course. Anyway, using the info on this forum I dropped the pan on my tranny and put in new gaskets and the superior shift kit. I ohmed out all the solenoids and they were good. I also had to repair gear on vss because it was so worn out that it made the odometer jump all over the place and caused the o/d light to flash and not go into overdrive. The problem I am having is what seems like the tranny starting out in drive and then going into overdrive. It is driveable but what happened to 1 and 2. I can manually downshift from drive and 1 and 2 work and then shift back up to drive no problem. Are the shifts so smooth now that I just don't notice. If I go from a dead stop in 1 or 2 it still starts in 3rd and then goes to overdrive after reaching cruising speed. There are no check engine lights fllashing or o/d light flashing. I am confused. Is there some sort of sensor that tells the tranny to shift back to 1st from a dead stop??? Are my 1 and 2 solenoids not working at all? Would I get an error code if the wire harness was broke. It doesn't blow fuses ever. Any help would be great. I may have to drop the pan again and replace the harness. Thanks!
Big Ben
Big Ben
