mooreg285
- March 10, 2015
- 04 Explorer
I need some opinions my 04 exp 4.0 xlt is idling very rough even more so when it is in drive not so bad when it is in N or P I replaced the spark plugs and this fixed it .... days later I replaced the 02 sensor bank 1 s2 and it was still fine now it is running horrible when I go to start it, it'll start fine rims shoot up to 1.5 then almost bottom out making the car almost die then will balance back out right under 1 and become like there is a miss in it rough. Then it will start to what sounds like a valve chatter or spark knock but will go away when rims are increased so I took all wires off made sure all had good connection and they did. I am lost I am going to try taking all plugs back out to make sure no gunk got on them while installing causing a miss in fire does anyone have any idea why it would only idle horribly but when rpms are up its ok
