cztexas
- September 4, 2010
- College Station, TX
- 04' Limited V8 4X4
Well, it is not easy to describe, but I will try my best:
04 V8 4WD, 100K
It is not a permenant problem. Sometime, when I make turns, one wheel may slip a little bit, the problem may occure; Sometiem, when I drive, passed a bump, the problem may occure.
When the problem comes, you will not feel any different unless you step on the pedal and gave gas to the car. Whenever you push the gas pedal, you can feel some vibration from the pedal. And also the abnormal noise comes with it.
Recently, I changed the front ball joints and cv boots. I donot think they are related. But I had a problem. One bolt that hold the rear differential is broken when I drove. It just happend right after 2 days when I bought this used car!!!! It may break the gear. But when I replace the bolt and differential oil, everything looks fine.
I think it may come from the Drive shaft or wheel bearing, etc.
Any comments are welcome. Thank you so much~~~~~~
04 V8 4WD, 100K
