Need Help!!! 06 to 03 Rear Driveshaft swap. YES or NO | Ford Explorer Forums - Serious Explorations
va2explorer
Hillsville,VA
03EX4.0,06EX4.6
I have a 06 V8 4X4 Explorer rear driveshaft with the larger u-joints.:thumbsup: Can I use the V8 driveshaft in my 03 V6 4X4 Explorer???? The flanges are identical on both ends, and the lenght of the shafts are the same. only difference I see is the slip joints are not in the same exact place, the V6 slip joint is about 2inches closer to the transfer case end of the shaft.
It works, no replies so I just tried it out.
