Need Help. 2" skyjacker or coil/shackles? | Ford Explorer Forums
oreokid220
Wyckoff, NJ
1993 EB
Hey guys I am tryin to see if I want a 2 inch skyjacker or coil/shackles. Post all your pictures and comments about these lifts. I think i am going to go with an add a leaf in the rear ad a coil up front but not usre at this point.
Thanks for the help deciding.
Jed
oreokid220@aol.com
hw much is the skyjacker lift? spacers and shackles dont really give much suspension travel boost, and they cost like 200 dollars when it all gets settled up.
So what do you like Brain about the lift and what do you not like. Also how was the install on those.
Jed
oreokid220@aol.com
i was thinking about the worn out springs and coils and rough country makes a 3 inch and a 4 inch lift, both are about 580 dollars, come with 4 new springs, not blocks, drop brackets, and 4 heckethorn shocks.
Jed
I really cant say much about how i like it since i have only had it on for a short amount of time. The ride seems about the same as stock. The front end does flex better and gives alot more droop.
The install was easy however I did much more while I had it apart. I also put in a front locker and shocks and brakelines. Just the kit itself was easy to install.
