00fordexplorer
- June 21, 2009
- ks
Hello everyone just found this board tring to fix my explorer! My 00 explorer is acting up BUT it only does it after driving it while seems like tho. Sitting at stop light it will surge up in down in idle 500-1000 rpms then when you try take off it will sputter real bad then take off or sometimes die... And at highway speeds it has some what of a miss but again it dont do it when you first drive it only after awhile... i dont think its a vaccum leak either as it only seems to do it after driving it awhile and its good and warmed up . BUT you can floor it and still rums fine. Check engine light is on. Went got the code came back as lean rich mixture says control module use the oxygen sensor to calculate airfuel reconized rich lean on bank one only . Its a v6 . Said problem list as fuel pressure or maf oxygen sensor , ignition misfire repair. fuel injector problem. Since it just does it after driving it awhile seems to me a sensor ?? Seems to get worse when you run the ac too. I cleaned the MAF no luck. Any ideas or what it could be ?? Im unemployed so like to fix it myself for lack of money but heading out soon to a new job 2000 miles away so id like it sound before i do so. Thanx for any help
