unpredictable1
- July 16, 2001
- AB, Canada
- 01 blazer lt
Need Help! AC Compressor is ALWAYS on/UPDATE: FIXED!!!!
Update: I fixed it last night and heres what i did. Ripped the whole dash bezell out, the piece all around the stereo, your light button and everything. Hauled the stereo out, hauled the heater controls unit out.
Plugged in the AC compressor, started the truck. AC never started automatically. got inside and turned on AC, compressor started. turned it off...it stopped. wtf??
Then I found something on the heater controls, that is located inside the dash when everything is put together. A small little lever. With the AC off i pushed the lever down, the AC came on. It must be some sort of manual override for testing.
Turns out from what I could see, the extra cables and wires from my stereo must have pushed this lever down (the AC didnt work when I bought the truck, I had a stereo installed right after purchase, so i never would have noticed this problem). I re-routed the cables and put it all back together and it works great. NOTE: I placed a nice strip of weather strippingunder the lever so it can't be pressed down so easily.
Thanks god this was an easy fix!!!!
And thanks to all those who replied!
A while ago for those who can remember, I had my AC replaced and it got upgraded to the new refridgerant.
I recently had a problem and some board members steered me in the right direction that it was the compressor that had seized....even though it was freshly rebuilt...anything can happen.
it got replaced today, and they found out something..
somewhere i have an electrical problem because my Compressor is on all the time. whether you push the AC knob in the truck or not. whether you just want to use the regular panel heat....AC is on and the compressor is running.
They did a very basic troubleshooting test and theres current going through the relay ALL the time. its always open.
where can i even begin to look to find this problem??? the actual switch mechanism/heater controls themselves??
Thanks!!
Leo
Thanks!!
Leo
