need help bad water leak and overheated | Ford Explorer Forums
hick31
lacey washington
99 explorer
found and fixed the leak it was the metal hose that covers the thermostat added water now it will turn over but wont start and water starts to fill over flow tank any ideas?
overheated
if you are getting coolant in your overflow tanks sounds like you blew the head gasket or cracked a head
Welcome to the site.If you pull the dip stick out. How's the oil? does it look milky?
no oil still looks the same
