AndrewB13ex
- January 18, 2017
- Burgettstown PA
- 1998 Explorer 4.0 SOHC
I'm completely stumped and need some help from anyone. Okay so I have a 1998 Ford Explorer Sport 4.0 SOHC 4 days ago had a code for engine coolant temp sensor I changed both everything seemed fine for one day woke up too go to work the next morning the car had no power very sluggish take off and would hardly make it up hills coming too red lights and stops it has a rough idle around 500 rpms and sounds too be sputtering. Before all this came about I changed the Gas tank, fuel pump, fuel filter, intake gaskets upper and lower, I was getting a lean code I did all that cleared the codes and was good for about a month now. So then yesterday still no power rough idle all day stays running just not the best did some research decided too do the plugs they haven't been changed in a few years figured why not put plugs in seemed too help a tiny bit but still very little power in the explorer and rough idle so today did more research decided too try the MAF sensor keep in mind I have no check engine light. So picked up the sensor driving home boom check engine light on check it and it's lean bank 1 so now I'm back at square one I put the new MAF sensor on cleared the light drive it back home 5 miles and boom the lights back on now lean on bank 1 and 2 i have no idea at this point I checked for vacuum leaks and there's nothing I'm out of ideas other then maybe 02 sensors? if someone could please give me some head way on things too try thanks in advance for the help
