Need help! Need info camber kit! | Ford Explorer Forums
MUDSLINGER4X4
BUFFALO, MN
2001 FORD EXPLORER XLT
My 2001 ford explorers camber is bad. Rear ended someone about a year ago. Ever since the camber is teribly off and i have replaced just about everything except the camber bolts and the a arms. Please help me!
Has an alignment shop attempted to align it?
What was the result? Any descent alignment shop should have access to a camber kit to get your vehicle back into spec.
i have gone to several shops and each would not even touch it. also would not give me info about the kits.
Just go to the local parts store and get them yourself and install em.. You need 2 sets of em.. One for each side. Its a simple procedure, you remove the old upper control arm bolt out of the mount and then install the camber adjuster with the new bolt for each side of the mount. Simple 30 minute or less job per side.
