geosnooker2000
- March 29, 2007
- Somerville TN
- '10 Eddie Bauer V8 4x4
It may be time for a rebuild (who am I kidding, of course it is, it has 320,000 miles on it), but I would like some advice on my first step to diagnose the problems.
1993 Explorer Sport
2WD Manual Transmission
320,000 +/- miles
I am the second owner, got her with 166,000 on odometer in 2000.
History - 2 years ago I was driving in the city in rush hour to a class I could not be late for. About 5 minutes from the University my radiator overheated and boiled out into the overflow tank. It started to run hot. I could not stop. I was within 6 or seven blocks of my parking lot, and I just pushed on to get there. It was weak as a kitten as I pulled in. Barely made it into a parking spot. I knew it was bad. I just let it sit there for the rest of the semester. I had it towed home. Surprisingly, after it cooled down, it ran as strong as an ox. Maybe I dodged any serious damage?
That summer I did my research and decided that I had cracked heads. I bought 2 remans from Alabama Cylinder Head (Look out. They are out of business now). I guess I should have had them looked over by a machine shop, but I am too trusting of a person I guess. I just slapped them on. New head gaskets, new head bolts, new plugs and wires, etc. I thought I did a slow and deliberate job. Cleaned the upper and lower intakes as thoroughly as possible, stuff like that. I fired it up and test-drove it for about an hour. It ran hot. Real hot. Then all of a sudden, something gave way and the temp gauge plummeted down to where it was supposed to be. It ran fine after that for about 2 or 3 months.
Then it started. The temp gauge on long trips would bob up and down, not like before the head change because of heat buildup and pressure release, but with the terrain and throttle changes. Uphill would drop the temp and then start to raise it. Acceleration would lower temp. Chopping the throttle would raise it. Kinda sounds like an ineffective impeller on a water pump? I might mention this was in conjunction with changing out the thermostat several times in order to eliminate that as a possible cause.
Whatever the cause, it was not bad enough for me to do anything about, and soon I was worrying about a far more sinister problem. I started noticing a puff of white/blue smoke on start-up every morning. AND, my mileage dropped from about 21 mpg to around 14-16 mpg. Valve seals? I put the truck on hold, and drove my 1996 EB 4WD instead.
Sadly, due to legal reasons, I don't own that 96 anymore, and need to restore this 93 for my DD needs. I started driving it last January, and just made damn sure I kept enough oil in it. Well, now I am using almost 2 1/2 quarts every tank. There are NO leaks. The driveway is clean. This has to be internal, but it is hard for me to believe I am losing that much oil through a defective valve seal. The engine could be getting 14 mpg because the cylinder walls look like a canyon wall, or the oil has fouled a plug or plugs, or I have a (or several) broken piston rings, or all of these.
If I'm going to rebuild this engine I need to get going. My senior year is fast approaching, and I need a DD within about 45 days. I think it would be a tremendous learning experience to do the work. I have a machine shop that has agreed to boar or hone, and clean the block for $250.
But if I don't actually have to go past the heads to fix this engine and make it run right, I don't want to remove the engine and spend that kind of money on a master rebuild kit.
In short, what is my first move? What do I check 1st, then 2nd, and so on?
Any help would be greatly appreciated.
George
1993 Explorer Sport
320,000 +/- miles
George
