Need help with headlights | Ford Explorer Forums
stevemya
NY
Explorer '97 EddieB
I changed the helogen lamp on a headlight (one side) but there is no light. What else can it be??? I thought maybe its the fuse but, it is only on one side.
Thanks in advance.
Some X's have a fuse for each headlight.
There is a seperate fuse for each side.
Or the lamp out module has a bad solderign connection.
Try interior fuse #4 for the driver side, and #8 for the passenger side (I think).
I really apppreciate your responses. I will try the fuse as soon as I get home.
Thanks a lot.
Best regards.
It's the lamp out module in the center console computer.
The fuse was fine. Its probably something else. What else it could be. What is a lamp out module???
Thanks.
He's talking about the message center in your center console. There's apparently a module in there that keeps the light from getting power if it thinks the bulb is out. So that sounds like something you have to go to Ford for. From what I learned when I bought my Ex and avoided buying a EB or Limited for that very reason, fixing anything regarding that damn message center is expensive as heck.
