akara
- March 16, 2017
- 99 Explorer XLT 5.0
Yesterday my wifes '03 4.0 explorer started acting weird going down the Interstate. Idling rough, acting like it has no power. Wife pulled off at a gas station and wanted me to drive the rest of the way to our destination. Resting it was running really rough, idle jumping like crazy, but no CEL. I got back on the highway and it was acting worse, and the CEL came on, so I changed route to an Auto Zone to get the code pulled. Get off the exit and it has 0 power. wont pull a hill. I pull off into a parking lot and after cooling for about 20 minutes, it runs well enough to get to auto parts store. Pulled codes are as follows
P0174 System too lean (Bank 2)
P0300 Random Misfire Detected
P0316 Misfire Detected on Startup (First 1000 Revolutions)
P0304-0306 Cylinder 4-6 misfire Detected
P2197 O2 Sensor Signal Stuck Lean Bank 2 Sensor 1
Auto Zone recommended fix is PCV valve, a $6 part with an easy replacement. Replace it and reset battery. Seems to be idling and running ok, but its also set for about an hour at this point. Leave idling for a few just to let it warm up, and no hesitation until i start to pull out. Acting the same and now won't go over 2k rpms even in park. As I already suspected, everything online for P0174 seems to point to stuck EGR valve, problem with MAF sensor, intake gasket bad, or busted vacuum line, but everyone else seems to only have the one code. Having reset the battery, the CEL won't come back on and I can't drive it far enough to let it reset and pull new codes to see if the PCV valve even fixed anything. Looking for tips or advice on this vehicle's issues from those who have had these longer than I.
