2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Sensor voltage?
Did you check the sensor voltage and the keep alive memory voltage?
Did the 5.0 engine run when you bought it? If so, I doubt that your PCM is bad. Your CEL illuminates when you switch to run. Do all the other normal indicators illuminate? Such as seat belt, air bag, O/D, etc? I lost my temporary Owner's Guide download to refer to. Does the 97 have a "theft" indicator? Is it active when you crank the engine? Even if your PCM is bad you want to make sure the wiring to it is correct before trying another.
