Omg>> i love it already
First to start off with the goods...
I got a intake spacer...
And the electric fan... The only bad is that when I went to test fit it after the motor was in it wouldn't clear the waterpump, idler, and hermonic balance... so it's going to lose some extra pounds and get skiny to fit in there.
I had to pickup some new plugs... so I went standard/platinum...
Here's some teaser pics... some final assembly before install
Ohh.. don't mind the finger... my younger brother didn't know until I showed him the photo... So I HAD to post it... hahahah
So here's the idea we came up with to be able to get the motor back in, drop the front end down even lower with the spindles just resting on deck lumber... it worked though.
The motor had to be lifted to as far as the hoist would allow to clear the fenders....
Then we had to ever so slowly let it down...
With the accessorie brackets on we had about an inch front and back to work with.
Then we ran into a problem... we had left the factory V6 mounts on the frame... b/c I thought it would bolt right up, well it didn't... The passenger side bolted right up... the driver's side did not... So since to be able to pull those brackets off we would've had to drop the front axle.. we did the next best thing... we took the V6 motor mount and traced the hole pattern to the V8 mount... Drilled it out.. and it dropped right on.
Without the intake the motor is SO far down there... plus the fact I have a BL... it made it much easier to get to all the exhaust manifold bolts... and the engine mount bolts.
Here's the BEST part... the finally resting place with the intake on...
Sorry about the blurry pictures.... it was 11:30 by time I locked up the barn and the Blackberry takes good pics... but sometimes they come out pretty blurry.
