AlaskanJack
Elite Cabin-Fever Captain
- March 24, 2002
- Centralia, Washington
- 91 , 93 & 01 Sports
I am wondering for all those that have done thier own ball joint swap if they had to remove the front drive axle as Haynes says to remove. I have removed my spindle and I cant see why I would need to remove the axle shaft.
Also, I ran into a problem when trying to remove cotter pin from lower ball joint. The end of the cotter pin has broke and I can't seem to get a grab on the looped end. It appears that the pin was shoved too far into the nut. Any ideas on how to remove this pin. I don't want to remove the axle shaft if possible. I am also replacing the knuckle this is why spindle has been removed.
