First, I have a 99 Explorer, Eddie Bauer Eddition. Last weekend I replaced a cracked EGR tube with a new tube. After the replacement, I started the explorer up and parked it on the curb. About an hour later I go to drive it and I can't get the engine to start. I cranks but wont start. I now notice that the red "theft" light flashes rapidly when i try to start it.
This leads me to believe it is a PATS issue. I bought the explorer for $500 and was only given 1 PATS key, which has worked fine up to this point. I don't really wont to dump much money into this fix. I would prefer to permanently disable the PATS, but everything I have read says you need a tuner to do that costing 3 to 4 hundred $. If anyone knows an alternative way, please let me know.
I have also read the trick about taping a key to the ignition. However, the 1 key i have isn't currently working. Is my only option at this point to call a locksmith or go to the dealer? If so, can I just buy a news PATS key and have them reprogram it or can the reprogram my current key?
Any advice would be appreciated. I just really need to get it started so that i can move it. Thanks.
