tac0meat
- May 29, 2000
- 91 EB 2x4
i just installed a conical k&n today and mounted it using a flange from a ricer shop. everything is hooked up good and tight. my truck will no longer run! i reset the computer . all my truck does is idle at around 500rpm for a second and die, even with my foot on the gas i cannot keep it running. at first i thouhgt it was those vacuum hoses that werent hooked up so i took that little metal thing with the two nipples on it out of the original air box and hooked the two hoses back to it and ran a hose from the intake tube to the sensor and still no change, what could be wrong?
