gijoecam
Village Idiot
- May 31, 1999
- Trenton, MI
- 98 ExSport, '00 F-150
93 Ranger 4x4, 4.0 auto. Replaced the radiator last weekend, so I did the hoses and thermostat too. (Looked like the "core" in the side of the radiator had broken loose, causing a temp rise at idle... oh, and it leaked) When I reinstalled the t'stat, I put the little check-ball facing up... was it supposed to be down? I'm still having an odd temperature problem... at steady state (idle or cruising on the freeway, makes no difference) the temp creeps up to the space beteween the R and the M, then drifts back down to the left edge of the N... I can't imagine that the thermal cycling is doing the engine any good (especially at 150,000 miles) but could this be caused by the t'stat being upside down? I need to pull it back apart anyhow... didn't get a good seal on the elbow and it's leaking on me...
Update:
OK, here's the scoop... I pulled it apart last night and found a couple of things...
1) Apparently when I installed the housing, I knocked the 'stat out of position. I managed to pinch the gasket between the housing and the head... hence, the leak.
2) The t'stat was in with the vent hole up... scratch that idea.
3) That third bolt is a pain in the butt to get started (the one behind the tensioner... I really don't want to do this again... any ideas?
4) Lower intake manifold gasket? I've been reading about it here... maybe?
I've got a couple ideas... maybe the water pump? I would think that it would only be a problem if the belt was slipping (which it isn't)
Sending Unit? Maybe the temp is just fine, but the sending unit for the gauge is whacked?
I can't figure it out... I'm stumped. Any ideas?
-Joe-
Update:
-Joe-
