Need to replace my engine | Ford Explorer Forums
All out
Ft Lauderdale, fl
2002 explorer sport trac
Any suggestions on which way to go? Drained the oil and all kinds of metal in it so engine noise and metal in the engine guess it's time to do something. Should I get one from a wrecked truck and change out the normal things that go bad or a long block.
Yeah my bad the 4L. That's what i was thinking is buy that do the the timing set and go on for hopefully a good amount of time.what timing set do you recommend?
You'll also need the special OTC 6488 tool to time the cams. It'll run you around 200, unless you can find someone to let you borrow it or have a tool rental place near you that has it. If you do have to buy it, you could probably sell it pretty easily on here to another ST owner.
Awesome thank you
All that's being done today hopefully it will be ready to go back in tomorrow
