Needing Bolt Specs Lower Control arm | Ford Explorer Forums
JCGreen79
Smiths Grove, Kentucky
2003 Mercury Mountaineer
I ran off the road and hit a stump. It bent my lower and upper control arms, broke the axle and the knuckle were the tie rod bolts up. I have replaced everything but my forward bolt to the lower control arm, it is bent. Does anyone know where I can find the specs for that bolt I didn't want to cut it it out until I have found the exact bolt to replace it. I've looked high and low and can't find the bolt size. it is causing an alignment issue. Thanks for your time
Thanks you so much. I really appreciate it.
