Bad doesn't even begin to describe what this guy put me through. Destroyed my 5.4L Block (dropped it and cracked it), smashed numbers on my $2200 Trickflow heads right on the valve cover surface so they'll now leak, put followers in backwards on my heads (yes this means he put the followers on and THEN torqued the cam down), assembled 2 RH heads instead of a L and R, lost one of my new valve retainers for my 306 and used a random one not meant for my spring, which in turn totally screwed up my spring height on that valve (he thought this was ok), told me to order standard pistons because the block was good at std bore, I got the block back and it was a 20 over 5.4 (I ordered custom forged pistons and waited months for them) so then had to buy a brand new GT500 block that was standard bore for almost 1000 bucks because I couldn't return my custom pistons, he threw my new $1500 set of Manley pistons and rods in a box (no padding) and they got all dented and scratched up, then also even though I gave him the Manley instructions, during balance he ground off material from the rod cap which Manley specifically says not to do ETC ETC ETC.
The guy was a real piece of work and denied everything. Claimed that retainer is what came with my kit (that's BS but regardless the spring height was completely wrong, why would you install it if it was the wrong retainer and not just call me?), he claimed my block was cracked when I dropped it off even though I had pictures of the serial number and the spot he cracked before I dropped it off showing it was perfect. He wouldn't give me anything, he was a real jerkoff pardon my language.
For anyone wondering this is Sigafoos Machine in Easton PA. Don't go there. Guy used to have a good reputation but has went severely downhill and is a 60 some odd year old baby. Wouldn't even talk to me, he stormed off and told me to get the hell out of his shop. He literally threw an engine block into the back of my truck and dented the side of the bed and almost crushed my heads in the process then stormed off.
