CougarSE
- June 29, 2006
- Lancaster, Ohio
- 84 BII, 98 Mounty
New BII owner here, I bought this back in March but only two weeks ago did I get to start on the buildup. Its an 84 with a 2.8 and C5 auto. Pretty typical trashed Ohio vehicle with lots of rust. The people I bought it from lifted it with f150 coils and short sections of 3x4 landscape timbers. :thumbdwn: Evidently the local parts house only had square u bolts so they used those. The whole thing fell apart and busted the driveshaft and leaf springs. If only they looked at the rotten body mounts and maybe tried to fix those they would have gotten the lift they wanted just buy returning it to stock height. Oh well.
My inspiration for this rig is 410fortunes rig, I've always been a fan of the daily driver/ trail rig and at the utmost importance RELIABLE.
Here it is the day it made it home. Notice how close the rear tire is up in the wheel well. The springs were cracked and the axle slid back. I had to buy a set of jack stands and a jack to start this project,.. oh darn
I decided to install ex springs since I had to change them and wanted to lift it anyway. I don't have a picture of them but they cost just under $70 from a semi local yard. I work alot and some times dont have a chance to make it to the local pick n pull.
To get the springs out I had to cut only one bolt, the passenger side front bolt, the rest came out fine. While it was apart I had to replace the driver side shackle as it was cracked badly. I had to cut that bolt too..
Here are the old springs out.
Here is the new shackle. Had to buy one for an 87 ranger because there was no listing for an 84 B2, they were however the same length.
And a shot of the rear of the B2 sitting on all fours again after being on jack stands for 2 weeks. In this picture the body is propped up to its stock height and remember we have f150 coils in the front. The ex springs lifted it up a good bit.
The body is propped up because of the rusted frame around the body mounts. All but the core support look like this one, some worse.
Now today I ordered new energy suspension body mounts from Jegs ( one of the perks of living in Ohio, Jegs has actual stores in Columbus) for $80. Cheaper than even ebay. With this I'm going to buy 5 3" lift blocks and cut them in half to have a 1 1/2" body lift. I'm only doing this to make future engine mods/and or swaps easier.
Now to repair the rusted frame I'm going to use this old trailer fender I dug out of the scrap dumpster at a local fab shop I had to do some work for. It is the same thickness as the frame.
Here is some more rust around the gate. its a pretty rusty beast but for a $300 rig that runs I'll take it. This area will get plated and nothing more. I'm not building a show queen here just a solid trail rig. yes that is an electrical box holding the rear of the body up for now.
In this picture you can see whats left of the gas tank shield, it is half gone. One strap is in two pieces and the other is almost the same.
Now when I have more time I'll post more pictures.
