sheltonfilms
- June 9, 2010
- Hoover, AL
- 2013 Limited 3.5L
I've been testing the Global Open function and it looks right now like a no go.
Programmed the BCM and added a wire to pin 25 on C2280C on the BCM (just like a Ford Taurus) and then added a wire to pin 33 on connector C3138 (door connector).
Tried it and got nothing.
Voltage at the door is 11 volts and voltage at BCM is like 2.9 both tested disconnected. BCM is supposed to pulse the wire to ground and it never changes when holding down unlock. Even made sure accessory delay was inactive.
If I knew what the pulse was suppose to be I could simulate it and at least see if the motors are capable.
