DLinkOZ
- June 26, 2005
- Frisco, TX
- 2004 NBX
Quick and simple, looking for input. I replaced one of my front hubs (04 NBX) and now it's tripping my ABS light over 20mph. My initial thought was no biggie, it's a snap to replace the hub so I'll just replace it. I remember seeing people have all sorts of problems removing the ABS sensors, so didn't even give that a second thought. I decided to try and pull the original sensor (which worked great) from the bad hub I removed since it was going in the trash anyway, and like everything else on my truck (knock on wood!) it came out super-easy (even has the factory blue grease on the inside).
So here's my question - should I just exchange the whole hub, or take a risk on the warranty (could be minimal, not sure) and try just swapping out the sensor? I would assume that the new one should be easy to remove, and since the old one came out easily it should be pretty simple and safe.
