New lift....Rocking back and forth and back and forth and back and forth and.... | Ford Explorer Forums
riffman
Bloomington, IL
'92 XLT
....ugh....im getting sick......
ok...just got the 5.5" superlift on, aligned, and everything. i did a custom soa in the back, and i also don't have any sway bars hooked up.
my problem is, once i get above 35 mph or so, somtimes it starts rocking back and forth....to stop it, i have to slow down. then it stops...and i can keep going. what is this caused by?
my caster isn't equal on both sides, could this be part of it? HELP!!!!!
Its your sway bars! Geralds does it a little bit to but not as bad as what you are talking about. What kind of shocks did you go with. I would hook your sways back up and try it that way.
[Mine does not do that. But I've got 3" less suspension lift and Edelbrocks.]Gerald
[Edited by GJarrett on 10-26-2000 at 01:48 PM]
i got the "bad" shocks....just the superlift ones, and i have heard nothing but bad things about those.....
i can only hook up the front sway bar though....the custom shock mounts went in place of the rear one. does that matter?
No, front sway bar is all you need. Rear is useless.
Cheers
Dale
