badmav70
- November 7, 2011
- jeannette pa
- 1991 exploader
hey everyone new member here, ive just come across a 91 explorer that was sitting in a garage and hasnt run in about 7 years.. i was told it was a great runner when parked but was taken off the road due too broken springs in the front and leaking trans lines... anyway
i have proceeded too try too get the truck running i have pepaced the fuel pump assembly with a new one, new filter, and that corrected the fuel too the motor problem, now i have 40lbs at the rail, the truck still wont run im getting spark if i hit it with starting fluid it will fire and run for a second or two.... injectors i checked with the noid light and they are pulseing what do you all think i should try next? should i suspect the injectors are clogged?
i have pulled a spark plug and it was not wet with fuel at all and other seggestions? id like too hear this thing run soon so i can move on too repairing the rest of it, body is amazingly solid
