New member | Ford Explorer Forums
New member
Swamprabbit
Forrest City, AR
2004 Ford Explorer
I'm new here. I have a 2004 Ford Explorer 4.0 4x4 Flex fuel. Before I drop the ball and purchase a motor I was needing a little info. The purchase motor is out of a 2008 Ford Ranger. Is there any thing I need to watch out for. Been reading through the threads on engine swaps. I guess what I'm looking for is the go ahead. Thanks guys.
Check all of the harness connections between the engines. In some cases manifolds have to be swapped to ensure you have the correct sensors, in the right locations etc...
Sorry I can't be of more help about this specific swap.
Welcome to the forum:chug:
Thanks Rick. The best I can understand from searching here is tear in down to the long block and put all my stuff over on to it.
Welcome to the site
Tony
Be sure to get as much wiring as possible. Even some of the same ranger motors had subtle wiring changes or plug styles occasionally.
Welcome.
Welcome aboard!! :salute:
Be sure to check out the 3rd Generation Sub-Forums:
Stock 2002 - 2005 Explorers
Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Modified 2002 - 2005 Explorers
Questions related to modified 2002 - 2005 Explorers and Mountaineers. For Sport Trac and Sport models use the 1995-2001 forum. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
Good luck and Happy Exploring!
