- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2025 Aviator Reserve 201A
- Callsign
- VE3... grid FN25hg
If your Sport did not come with Active Park Assist then adding the feature is much more complicated than just adding the button. The feature incorporates all the sensors to allow for parallel and perpendicular parking and also is integrated into the steering system. Check out the feature in your Owner's Manual.I saw a reference to a Parking Assist using that third button on the LIft-Gate, Tow panel. Is that a good thing to add to the Sports, and if so, where would I start?
I believe the temperature display disappearing is a common thing when plugging in your phone for certain functions.
Are you actually planning on towing? Just curious since it has been over 2 years since you bought the vehicle and just now mentioned the towing button issue.
Considering the temperature you stated, the heated steering wheel should come ON every time you start your vehicle. I believe it is all covered in the Manual.
