beavo040
- December 23, 2014
- Mesa, AZ
- 2000 Ford Explorer Sport
2000 Explorer Sport 4.0SOHC RWD
What started off as a simple radiator replacement, has progressed into a non-cranking headache. I can't fathom how swapping out a radiator could possibly have anything to do with the current non-starting issue.....guess it's just a coincidence. Never had any starting issues until installing the new radiator, but I guess that's just my **** luck paired with horrible timing on failing parts. After removing the old radiator, I noticed the t-stat housing was cracked. Ordered and installed new t-stat and housing, installed the new radiator and buttoned up all other remaining connections and hoses. 1st attempt to start....nothing. Realized it helps to reconnect the -neg battery terminal (F'n idiot). This time upon key turn, just a single clunk, almost a thud even.....but no crank. Immediately thought starter, but couldn't convince myself that the starter decided to just take a **** the same day the new rad. went in. Since I did remove the alternator to make working with the t-stat housing easier, I double checked to make sure I didn't leave anything obstructing any of the pullys or moving parts. All looked good. Fearing the worst, I threw a ratchet on the flywheel to see if I could turn it manually or not. Had no problem turning by hand, and no unexpected noises heard while doing so. The clunk heard when turning the key is rather loud and can even be felt. Every starter I've ever lost, just died out silently, and I've never know for one to make this type of noise. I'm sure the starter got plenty saturated with coolant from the cracked t-stat housing. While I'm sure that's not healthy for the starter and may even kill it, I wouldn't think it to be the cause of a loud clunk, followed by no cranking. I would really like to get her up and running for the holidays, but I'm simply dumbfounded. Any advise or insight is greatly appreciated.
