New Spring Questions | Ford Explorer Forums
jprevat
South Carolina
1989 Bronco 2
I have a 1989 Bronco 2 I have decided to turn into a weekender/hunting rig. I am trying to get some explorer springs to run up front and in the rear. Will I get any kind of lift from the use of the ex coils up front? I like them for the heavier spring rate because of the winch and bumper I want to put up front. If I do need coil spacers up front would I need to buy some for explorers or B2's.
Thanks in advance guys!
If they are brand new coils you will have a bit of a lift until they settle. As far as I know they are the same springs.
As for the rear if you get leafs from a 4-door Explorer you should get about 2 inches in the back.
